Hi,
alarm was playing up yestrerday ( H & P: pa1000 ) - and going off after I'd locked the car[>:].
Didn't have time yesterday, and alarm seemed to turn itself off and not start up again.
So plan was to sit in it today[8D], and go through the alarm bleeps / flashes from the led - to find the fault code...BUT went to use the remote - nothing - remote central locking wouldn't open it [
]( recently I've had to stand closer and closer to get thsi to work )
[:'(]The leds on the door lock pins weren't flashing either[
So opened the door with the key, and saw the alarm led on the centre console was not flashing.
Put key in ignition and turned on - but nothing from dashboard - none of the usual advice lights etc,. that come on when you turn on th eignition, and obviously nothing from trhe engine.[X(]
Thought 'B#gg#er' - car battery must be totally flat[8D], so took it out and put it on charge - but charger is showing virtually no current running to it - so either the car battery is absolutely dead,
or something much worse is going on with the alarm / electrics??[:'(]
Any ideas on what to try next??
Thanks T[&:]
Thanks T[&:]
