Diagnostics code help please 996 Turbo S
getitupya
Hi All,
I am getting various intermittent faults occurring on my 996 Turbo S, starting with the old favorite;
- PASM/ABS (this used to reset as soon as engine warmed up, but now stays on)
Then not so often (happened 4 times in all)
- the TIP gearbox defaults and sticks in 3rd (if you stop and switch ignition off, it clears)
and a couple of other randoms
- Spoiler not activated (it had)
- CD changer not located.
Living over 2 hours from any specialist or main dealer I took the car to a local "diagnostics center" and was left with the following when they reset the codes on the initial download and I ran the car for a short period.
Code 1 -
22 CAN: rear right wheel rpm from PSM implausible
Code 2 -
51 Transmission slips or gear implausible
Identification:
Diagnostics software number - 0102
Porsche part number: 9966181800
I am a bit confused as the code 0102 is for the MAF I believe and the part number is showing as the tiptronic control unit??
What should be my course of action?? Would swapping the rear wheel rpm sensors over be a good starting point and see if the fault changes to left rear?
Worthy of note that the PSM/ABS fault existed before a flat battery where the other faults have only appeared since the flat battery.
Thanks in advance!!
I'm not sure those Tiptronic fault codes are accurate. I assume they didn't use a Porsche tester, in which case they will be generic codes, rather than Porsche-specific ones. However, they do give a clue as to what is going on.
The P0102 DME code is, as you say, a faulty MAF:
P0102
115 Mass air flow sensor "" below limit
Diagnosis conditions:
"¢ Engine running
"¢ Battery voltage greater than 8 V
Possible fault cause:
♦ Open circuit
♦ Short circuit to ground
♦ Mass air flow sensor faulty
A faulty MAF is not programmed to trigger the Check Engine light on a UK car, but it will trigger the PSM/ABS lights. The reason is because the DME and ABS/PSM controllers communicate via the CAN bus, and the DME is sending an implausible signal to the ABS/PSM module due to the faulty MAF readings. The Tiptronic unit is also communicating on the same CAN bus, so it too is getting implausible signals.
I would fit a new MAF.
The spoiler and CDC are not related to the MAF problem, and are individual faults which need dealing with individually.
Thanks for the reply Richard, I will source a MAF and try that.
I guess the wheel speed sensor needs changed also, or is worth waiting until I have done the MAF?
cheers
Murdo
I would wait until you have done the MAF, which might be causing the other fault codes.
Like I said, the fault code you have for the speed sensor (22) isn't a Porsche code, so I would be wary about it being for the correct wheel.
