Firstly rest in peace DB as I'm sure many of us have listened to his music whilst on the move and will continue to do so.
Well for the first time in 6 years of owning the car it refused to start last Thursday morning. I hadn't run the car for about a week when it had been perfectly OK so I was surprised it didn't fire up although it turned over fine. As you know its been a bit of a damp winter so I thought initially it was a damp issue so gave the engine bay a liberal spray of WD40 and put the car battery on charge overnight so that it would turn over with more vigor to next morning. In the mean time I removed the DME relay and tested this as per "Clark's Garage" instructions (what would we do with out him?) Anyway the relay checked out OK although I did notice some small cracking around some of the contacts but whilst working best to leave as is.
The next day after replacing the DME relay I tried to start the car but no joy, but again it really turned over well but did not fire, which leads you to think that it is a fuel issue. So the next item to check and is the easiest is the DME Engine Temp Sensor with the blue connector at the front of the engine block. On checking "Clarks Garage" he gives the resistance readings of the Temp Sensor and so as the engine was cold I checked its resistance which was about 4200 ohms, (guessed at 15c) if you look at the chart below this would fit nicely and reflect that the Sensor was OK. I then gave the connector a dose of WD40 replaced and tried to start the car. Yippee it fired up straight away as if it had never had any problem.
So this is my second issue with the Porsche over the 6 years and once again caused by a connector problem even though it was all connected OK, all I can imagine is that the vibration over the years is causing intermittent resistance's being read by the DME which it turn gives us all these wonderful experiences
data:image/png;base64,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
