chriscoates81
Hi guys is the only difference the size of the springs between these 2?Also is the m029 kit available for a similar price to the m030 kit?
Chris
Chris
ORIGINAL: Richard Hamilton
It is the spring length which gives the ride height. The dampers for both M030 and M029 are the same type (Bilstein B4) but the valving is different to give different damping rates. There are several different springs for C2, C4, C4S, Turbo, and Coupe/Cabrio versions of each (not to mention Targa) dut to different weight, etc. Also there are several different anti-roll bars. It can be a minefield.
What exactly is the problem, or what are you looking to change about the current setup?
