EddySpaghetti
Hi,
I wrote a post a few weeks back describing the fact that I couldn't get anything but third gear. Basically the problem seemed to be a dragging clutch, because third gear was a fluke - I couldn't really engage / disengage any gear.
Since then I have changed the slave and master cylinders, and the flexi pipe from master cylinder to the solid pipe. I have also thoroughly cleaned out the reservoir and trimmed the short flexi from the reservoir to the master cylinder to cure a little bit of splitting which had appeared (but not yet made it past the jubilee clip.
The fluid in there was brown with rust, and I think I found a leak at the slave cylinder - basically both seemed well past their best.
Unfortunately I finshed the bleeding process last night and my 'fix' hasn't worked - I was able to go backwards and forwards a few times in first and reverse, then thought I'd brave a journey on the open road and before I had got to the kerb my first gear 'locked in' and reverse wouldn't engage - I had to turn the engine off to select the gears required to park up again. Shit, and I was suposed to be driving it to Scotland this weekend...
I am still hopeful that I don't need a replacement clutch, becasue the distance I had between the actuator arm and the front of the inspection housing was well below the 34 mm quoted in Clarks garage and the haynes manual - has anyone got any tips on what else this could be, or how I can check to make sure I have bled everything properly? - the fact that the fault occurs a couple of minutes after the last bleeding I have done suggests to me it isn't a collapsed clutch, but a problem with my bleeding technique?
I used an Eezibleed kit though - and thought I got the procedure correct? - do I need to cycle the clutch pedal while bleeding under pressure - that would kinda stop this being a one man process....
Thanks for any thoughts - I'm a bit distraught that I can't drive it this weekend, which means no visit to Alasdair in Bonnybridge, as well as the thought of having the clutch done....
Cheers,
Eddy
Cheers,
Eddy
