Differential reinstallation
Paul Fraser
Does the collar joining the differential to the transmission shaft have to go back in the same alignment as it came out for balance reasons? Thanks.
Struggling to understand what part you are talking about. The diff is bolted onto the crown wheel isn't it? If you are talking driveshafts then they can be fitted in any orientation (in fact you are supposed to periodically rotate them) so don't need to be installed in the same orientation they were removed.
