1. Pulse generator, (or flywheel sensor, call it what you will) It is indeed the so called Series Two, but just to be clear it is in the main going to be the 177 bhp engine; there will be a box of electronics under the heater matrix, and just a rotor arm in the distributor. 924nutter 924 Turbo S2
2. "What does anyone do for big end and main bearings as the OPC say they are no longer available for the NA 2.0." Is there another source? Vince Matthews 924 2.0
3. Metal water tubethat connects the 'hose with the bleed valve on' to the 'the n/s hose from the top of the radiator' part number 047 121 073A Vince Matthews 924 2.0
11/5/2010 Just thought I'd add a bit of news. I've found a company that can fabricate the now unobtainable water tube 047 121 073A for an reasonable one off price. I had it made in stainless steel though you could have mild steel too which would be slightly cheaper. If there was enough interest on the forum I could approach them about the costs of getting a batch made. Vince Matthews 924 2.0
