dim instrument lights
- Thread starter Jonny B
Could be worth trying a replacement dimmer pot too or cleaning up the one you have (labour intensive but cheap) to reduce resistance.
sawood12
Diver944
Clarks Garage has a good write up with pictures:
http://www.clarks-garage.com/shop-manual/elect-08.htm
Has anyone tried the Xenon bulb in the dash yet?
Charles
Fred Hindle
Bought mine from www.ultraleds.com - direct replacement and I can now see the dials.
Cheers,
ORIGINAL: Fred Hindle
I have old style dash - replaced bulbs in the speedo and rev coumter with LEDs. Different bulbs in other instruments and never found LEDs that fitted.
Cheers,
Fred,
I bought some LEDs from them too but only found a slight improvement over the standard 2w ones.
Charles
http://www.cml-it.com/pdf/EAC_article07_march_april.pdf
and spec
http://www.rapidonline.com/netalogue/specs/41-0766.pdf
They are available from Rapid Electronics for merely 48p a piece for the 3w with a 10,000 hours life.
Me decision now is 3w or 5w? Any suggestions?
Charles
http://www.rapidonline.com/productinfo.aspx?&tier1=Electronic+Components&tier2=Optoelectronics&tier3=Miniature+Lamps&tier4=Xenon+lamps+%26ndash%3b+wedge+base&moduleno=75683
I may also get some new holders too for a complete makeover [
Charles
Fred Hindle
I found them to be a great improvement. Perhaps a case of perceptions. 944 has yellow lettering whilst 924S has white so can't put it down to colours.
Please let me know how you get on with the Rapid bulbs, it maybe the way to go with mine.
Cheers,
Fred
ORIGINAL: charles.y
Does anyone know how much heat (temperature wise) a standard T10 wedge base 5w and 3w bulb will generate?
Charles
IIRC from my (somewhat hazy) student days something like 95% of the energy consumed by a filament light bulb is heat [
After a number of not quite successful attempts and now I think I may have found an alternative (and cheaper cost) solution to cure the common dim instrument light problem. The results is actually much better than in the picture.
The bulbs used in my solution are the new T10 Xenon filled bulbs from CML-IT. They claimed they are 30% brighter and 30[FONT=comic sans ms"]ºC cooler on the glass wall temperature.
[FONT=comic sans ms"]501XLF T10
[FONT=comic sans ms"]1503XLF T10
[FONT=comic sans ms"]501LF T10 Argon 12V 5W 139ºC
Since they don't do 12v 3w standard argon bulbs, he reckons the max temp for them may be near 110ºC. If what they claimed is true about the cooler glass wall temperature then the max temp of the equivalent argon fill bulbs should be:
argon 12v 3w 110ºC
argon 12v 5w 142ºC
and therefore the Xenon 12v 5w (112ºC) bulbs should be quite safe inside the 944 instrument cluster. I have tested both the Xenon 5w and 3w bulbs inside the cluster and the results are very impressive. The 3w are already big improvement over the standard 2w bulbs and those LED bulbs that I use inside my cluster until now (the LED are better than the standard 2w bulbs). When I swapped those Xenon 3w with the 5w ones, its no doubt that they are the to go for. Its brighter than the Xenon 3w and soooooo much brighter than my LED and 2w bulbs (different league).
I have switched on the cluster lights fitted with the Xenon 5w bulbs and have them on for 2 hours and there are no issues/burnt smells/problems.
Total cost: £1.89
Parts ...
3 x XENON LAMP WEDGE BASE 5W (RC) bulbs (cost: 3x48p = £1.44p)
3 x WEDGE LAMP SOCKET (RC) sockets (optional - you can keep the old ones) (cost: 3 x 15p = £0.45p)
They can be ordered from Rapid
http://www.rapidonline.com/productinfo.aspx?&tier1=Electronic+Components&tier2=Optoelectronics&tier3=Miniature+Lamps&tier4=Xenon+lamps+–+wedge+base&moduleno=75683
Please note I have no business interests/connections with CML-IT or Rapid and hold no responsibilities for any damages that my suggested solution may have caused. Good luck.
Charles
Fred Hindle
Thanks for the information. Just need to suss out if the twist lock connections are okay for the early dash models.
Certainly a bargain price.
Cheers,
