Disc sizes
OT, sorry but while you`re all on about discs. How much cracking is normal in front drilled discs (They arent Zimmerman)
ORIGINAL: random hero
Cheers scott, are they also 24mm thick ??
Not sure, my manual only says that the minimum thickness is 22mm (i.e. worn) so I guess 24 or maybe in the right ball park - probably more because you must get more than 2mm of wear on these things.
S2:
Brake disc dia. front 298mm, rear 299mm, active disc dia. front 245mm, rear 246mm
Thickness of new disc: front 28mm, rear 24mm
Wear limit: front 26mm, rear 22mm
