i want to disconnect the battery so i can charge it up. The car has 2 fobs a laserline fob with buttons on it which work the doors and alarm, and a laserline fob that presses against the led to turn the omobilisor off. I want to if i disconnect the battery will the alram and immobilisor work when its connected again, or will i have to press a sequence of buttons to make it work again. i dont have any documents/instructions for the alarm you see. as its a failry common system i thought some here might know. ta.
discinnecting battery??
- Thread starter soooty
Fred Hindle
You could always rig up something so that the memories are retained (similar to those little devices used in garages to prevent the radio codes having to be re-entered). If your cigarette lighter socket isn't always live then see below.
If you have another 12 volt battery with a bit of life in it them run some wires to the car's battery terminals before disconnecting the battery.
Cheers,
Cheers,
I've done it ok with my Clifford (and years ago a Moss!)
Mike
Mike
