Hi all,
My car is not running to smoothly at the moment. I have checked the following out: Looking into the engine bay from the rear of the car I have: Removed the left hand coil lead, and started the car up, it runs, I have then replaced this lead and removed the right hand side ignition lead and the car will not run, I presume the problem is the belt has broken or the coil pack has failed ?
The car ran ok, but under normal exceleration would be a bit off on and not smooth, from 4000 rpm it would pull fine.
I understand that the car has 12 spark plugs, 6 from one distributor and 6 from the other.
comments welcome
Thank you
Stephen
comments welcome
Thank you
Stephen
