Hi.
Started car testerday, idled for about 20 seconds then cut out completely. Flattened battery after leaving 20 mins between attempts. Fuses ok, Fuel ok, put in new relay under pass.seat. Still no joy. On checking distributor rotor arm, the shaft it attaches to also came out and at the bottom of the casing there were two springs sitting unattached to anything. What do these attach to, there seems no obvious points. One is slightly larger than the other. Do I need a new distributer and any idea how much these cost. Any help greatly appreciated. First 911 and this is only day 5!!! Cheers
