Has anyone personally changed an oil cooler? If so whats involved? Thanks John
DIY oil cooler change
- Thread starter johnsaunders
Andy B Aces High
Hi John,
I did my Oil Cooler a couple of years ago, nothing too difficult although the fasteners will probably need some persuading. If I remember correctly the headlight needs to come out which is fairly easy from inside the front luggage compartment.
I found that my fan shroud had become distorted over time so I changed this as well, the foam strips around this are also worth doing and also worth changing the Temp Sensor which is mounted on top of the cooler at the same time unless yours has been done. Most important is to ensure you plastic bag the ends of the hoses whilst working on the system to keep any debris from getting into the oil system also ensure you use two spanners on the hose/cooler connections to avoid strain on the welded unions on the cooler.
Might be worth checking PCar. com or one of the other forums on the net as there will probably be some info on there.
Andy.
Andy.
Andy B Aces High
Sorry John,
Should have been Ballast Resistor NOT Temp Sender !! This controls the two speeds of the fan.
Andy.
Andy.
Hi Andy.
Thanks for the info.
With the headlamp removed the hose connections are visable.
Do you recall if the nose cone come off in one piece?
I understand that the wheel arch liners need to be partially un screwed for the nose cone to be removed?
John
John
Andy B Aces High
John,
If by Nose Cone you mean the front nose of the car then you do not need to remove this, just remove the front wheel arch liner and headlamp and you should be able to get to everything you need to.
Andy.
Andy.
Hi Andy.
Thanks for the advice. I have changed the cooler successfully, once you know how its done its fairly straight forward.
John
John
Andy B Aces High
Glad to hear the job went okay John. Like you say not too difficult.
Andy.
Andy.
