mcgc0
Have the C4 which had a completely dead battery while having some minor paintwork done over 5-6 weeks period. Tried jumping but realised first hand that unless the 'donor' battery on the other car is up to it or (almost) the same spec as well it still ain't gonna fire up. It turns over (just) but that was all. However, strangely enough after recalling a couple of previous posts I'd thought I'd give switching DME's a go even though the one I had was fine. Did this and presto - we're in business and she fired up immediately!
After a day or two of driving around I swapped back to the DME out of interest and that works fine too - although a tiny tiny longer on turn over before firing up but fine otherwise. But, for some reason the fuel pump whine up front is permanently on regardless how long any journey is. It never used to do this for some reason. Swapped over the DME again this morning and that has made no difference - loud whine still there. So, a couple of questions...
- What is that loud whine? Maybe getting a new DME might cure this? Or is my pump knackered?
- How or what makes a DME 'degrade' or differ from the next when using my dead battery or slower firing up as examples and can DME performance be measured (test bench or otherwise)?
Thanks in advance chaps...
