notechmike
I bought my Boxster in March this year (it was first registered 25th May 2006) and when it was in my OPC more recently I asked that they give me print out of the over rev record. The report showed 655 ignitions in range 1 and 44 ignitions in range 2 - I assume this is nothing to worry about?
Further down the report it reported "total distance". This was recorded as 17952.000. Not sure if this is Miles or Km but if the latter then this would equate to 11154 miles. My speedo stated ~11600 miles (I didnt actually check it at the time hence the approx figure). So if units are Km on the DME report then there is just 400 miles that's unexpalined but if the units were Miles then the difference is over 6000 miles. My questions:-
Is the "Total Distance" the distance the car as travelled ie equals speedo distance?
Is the DME units Km or Miles?
What scenarios would expalin the difference?
A fact that may have a bearing on this is that a month earlier I had the PCM swapped out under warranty (single cd was not working). Is this data storred in the PCM or elsewhere? Also shorly after I had the PCM swapped out, the service indicator warned that a service was due sometime in early June although 2 year service should have been due in May had it not been service by the OPC as part of the purchase 2 months earlier. Is the service data storred in the PCM or could this just be a coincidence that the original dealer forgot to reset the system when he serviced it?
Can anyone explain these apparent discrepancies [&:]
Mike
Mike
