DME relay
sawood12
Why did you purchase one from Porscheshop? They're cheaper from the OPC. Anyway, you'd use it if you have starting problems that may be due to starvation of fuel and it goes in the fusebox.
^^ What Scott says pretty much ^^ Depending on the year of your car its either under the glove box above the fuses (pre 85/5) or in by the fuses under the bonnet on a later car. DME relay controls the supply of fuel and works in conjunction with the ECU, you basically end up stranded unable to start the car when they fail. My Spare at the moment is from a Nova GTE, same DME replay [8D]
Dear All - have been reading a lot about the DME relay and that you should keep a spare in your glovebox etc so have purchased one from Porscheshop. Question is (excuse my ignorance !) if I need to use it, what do I do and where does it go ?
