DME relay
dave364634
the dme is a common fault. make a 'thing' out of wire and spade connections, that connects the big three together. if that sorts your problem it's new relay time. :)
I am having trouble starting my 83 944, i have power to the fuel pump, Fuel pump fuse and supply to the DME relay, i have no spark,
My question is does the DME relay control the ignition, and could the relay be the cause.
