DME RELAY
- Thread starter gresley
szklarek
clyde
Yes indeed it can. If I was a betting man I would put a substantial amount of money on the DME relay as being your problem if that's your symptoms. The earlier 994 numbered item is the one that's prone to failure, I don't think the revised 993 numbered ones have been known to fail, so don't see the point in carrying a spareORIGINAL: gresley Can the failure of this be intermittent ? I.e. can engine cut out and then restart 40 secs. later when turned over on starter. You can guess why I am asking! Andrew W.Â
clyde
Just checking that you were paying attention []ORIGINAL: pse_SC I think you mean 944 numbered item, clyde.[8|]
