DME
- Thread starter Guest
A replacement relay is cheap and can be fitted in minutes by yourself. If you Porsche is running fine you can keep the old one as a spare.
If you suffer any type of intermittent running fault this relay is worth replacing .
The Boxster DME is found in the rear trunk on the left side of the firewall.
![Boxster%20DME%20Location2%20sm.jpg](http://www.rennsportsystems.com/Boxster%20DME%20Location2%20sm.jpg)
You did - DME = Digitale Motor Electronik. ECU to you and me!
