Hi folks,
I'm currently in the "˜umming and arrring' phase just before making a new purchase which could be an early Boxster S. I wondered if I could share my thoughts and gain your advice.
Firstly, my background as this possibly helps with context:
I've got an ultra reliable 53 plate BMW320d M-Sport Coupe which is use for business miles. It's just turned 100,000 miles and other than tyres, services and one set of brake pads & discs it's not needed anything. It still has a tight gear box, tight suspension and squeaks or rattles "" so I've decided to hang on to it (it seems to be worth nothing now anyway).
I also have a motorbike "" A Suzuki GSX-R 750. It's all the fast road bike you could ever want. Again, it's fairly old (52 plate), but hasn't done many miles and I've no desire to change it right now.
What do I want? .... Plainly and simply a "˜new toy'!
My thought process:
Build a catherham roadsport "" I've decided against this, as they are more than I wanted to spend and really it's not that different from the motorbike (not very comfortable and would never use it in the wet).
Lotus Elise S2 "" Slightly more comfortable, but they all seem to have been tracked/thrashed and I hear bad things about the K-Series engine's head-gasket.
Porsche Boxster S "" I thought I had found what I was looking for. I'm aiming to spend about £10k and there's a few around with 60-70k miles. It looks slightly more civilised than the above. Only problem is this RMS sensor issue. It seems that if it fails (and it looks like a lottery) then it's £10k to replace the engine. Start's to seem worse that the Lotus' head-gasket issue!!!!
My plan was to buy a car that wouldn't depreciate too much over a couple of years and I thought the Porsche would/could be the one, but with the RMS issue I could lose the whole £10k due to a silly seal!
If you look on autotrader/ebay there's a few around for the £10k (ish) even one with a new engine (due to RMS failure!!!) .... I'm I barking up the wrong tree here? At £10k would I be buying a world of pain?
Anyone got any advice????
My thought process:
