Hello, All
When driving in the dry, I find the 3,2 to be a very fast and predicatable car. It gives endless miles of delight from here on the wild roads North Wales down to the hairpins and fast straights of the French Alps. However, in the wet, it as a whole different story, and I wonder whether it is just me (or my car).
When the rain comes down, the steering goes light, and the car *feels* as though it will understeer. That is, Understeer! with a capital 'U' and an exclamation mark. At the same time, the rear end can be cause to break away under power - I have experienced this in fourth gear and 3/4 throttle! Then again, shedding speed - even in a straight line - is not always easy, because locking a front wheel is so easy (that makes UNDERSTEER! - all capitals).
So, just the other day, I was driving on a wet Welsh B-road, and came downhill on a long straight towards a series of sharp downhill bends - a bit of road that I know quite well, and that I could storm in my Lotus Excel. Looking ahead, I just had no idea what the car would do. I hardly dared press the brake pedal in case of a lock-up so I started braking way early. When I did, I got that weight-pushing-from-behind feeling that all 911 drivers know. Anyway, I ended up approaching SO slowly; sort of Morris Marina with worn-out bushes speed! I still did not know what the car was going to do.
So, the oft-repeated mantra is "slow-in-fast-out". But you cannot do "fast out" in a 911 in the wet, because the rear end will slide away (thankfully quite slowly). Compare this with the 944 technique (in the wet) of stick-it-into-second-and-give-it-full-welly even part-way round a roundabout. I tried to do moderately fast out after an Audi TT and got the back end sliding away in fourth gear (while the Audi disappeared off... way, way off).
My car is well looked after and has 4mm+ tread on its Michelin Pilots. So, what is the real story? I can see several possibilities.
1. After 21 years of driving RWD sportscars and 18 months in a 911, I still have a lot to learn about the 911, and that I can eventually learn to predict how it will behave.
2. I have a big problem with my car that no garage (Shirleys, Tony Greatorex, 9M) has dared to tell me about yet.
3. They are all like that - it is not a problem, it is a feature.
4. They just *feel* understeery and nearvy in the wet - I just haveto trust it more.
5. The tyres are crap.
Any thoughts?
Alistair
PS - I started writing this before reading the current edition of 911 and Porsche World, and the article comparing the wet weather behaviour of the 944 Turbo and the rear-engined cars. Amybe it is something that just is part of the 911 experience
Any thoughts?
Alistair
