Do you recognise this?
- Thread starter rcsalmons
ORIGINAL: rcsalmons
Temp sender for the turbo apparently
no apparantly about it - its the temp sender for the auxilliary water pump that cools the turbo and runs swhen you witch off the engine
If you have caned it and shut the engine down immediately (not recommended) it may extend the run on time. Basically if the pump runs after you switch off dont think the sensor is ok. If it is 'wobbly' it probably needs replacement, used to be not very expensive from an OPC.
Tony
Tony
