Dodgy clutch pedal
- Thread starter jetbox
Waylander
you might need new slave or master cylinder,
the brakes always get flushed and new fuild no one ever does the clutch, so the fuild gets full of water and rots the cylinders from inside out
to check which one you need,
check for fuild just below the master cylinder inside the car where the push rod comes through the firewall,
the slave might not be so obvious to see fluid leak,
Waylander said:have you checked the fluid level?
Second that. Had these symptoms for about 6 months last year. Replaced the slave cylinder, all sorted.
