Evening All,
Have an issue when changing down gears. Clutch feels fine and all gears will select no problem apart from reverse which can take a couple of attempts to get in , but all other gears both up and down are fine but when changing down into 3rd there is a small vibration/judder from what feels like under the gear stick but when changing down to 2nd there is a massive vibration/judder from the same area. Also the bite point seems extremely high and a little stiff/sticky/jumpy and generally not smooth. ( what great description )
Any ideas what might be causing this. Help would be most appreciated as the rest of the car really is superb and want to try and resolve quickly as the rest of the car is excellent.
Simon
Simon
