sawood12
OK, the doors are held on by two hinges and have a flat bar roughly between the hinges that is pivoted on the door frame and dissapears into the door as you close it. Normally (i.e. in other cars) this bar is attached to some sort of spring-loaded mechanism that holds the door at whatever position you open it to and generally creates some resistance when opening the door. On my car both doors will not hold themselves in any position and this mechanism doesn't appear to be having any effect so my doors effectively flap around with no resistance, which makes it awkward in car parks because you always have to have one hand on the door to stop it from contacting the car next door.
Is this normal or has my mechanism somehow failed?? I am intending to take off my door cards in the new year to grease up my window regulator so if there is a problem here I could do with sorting it out at that stage.
Cheers.
Cheers.
