mik_ok
I have an intermitantly sticky drivers door lock barrel. Tried a couple of WD-40 applications and it aint fixing the issue. Can make getting into the car a pain......
OPTION1
I therefore want to pop the barrel out and strip it down.
From the manual (thanks Rick) [
1. Door card removal ~ appears to be screws only. Can someone confirm there are no nasty "self-destruct" clips?
2. Internal "door pull" removal.
3. Window and rail removal. Can anyone confirm whether this is absolutely necessary? I'd obviously rather not if I can avoid it.
4. External handle removal.
I assume the barrel can then be removed from the handle (?)
Thanks in advance folks [
OPTION 2
Can I buy a new barrel to match my existing key? I'd rather not change both doors and boot just 'cos of this issue.
If I currently had access to a computer other than my laptop I guess I could check PET myself via the disk that Mr Coull kindly sent. [&:]
