I appear to have a broken/ disconnected part of the door handle mechanism. The passenger door was working perfectly well the other day, even on the central locking from the drivers door. Now its resolutely shut.
The tab inside the door only goes up and down about 3 -4 mm. I understand there is a linkage that can break or become detached within the handle mechanism.
How do I get into the mechanism with the door shut?
It appears to be impossible to gain access without destroying the door card? Is the fact that the lower edge and trailing edge fixed with poppers a clue to gaining access. The leading edge has a screw at top and bottom that cannot be accessed with the door shut. I think you would need to be a contortionist to get in via the rear/bottom edge of the card
Eddie
Eddie
