Trivial I know, but I need to investigate why my pax door mirror has stopped demisting. Driver's side is fine.
Anyone had this issue and found an obvious cause? I assume it's on same fuse as driver's side? Guess I'll start by pulling the glass off and see if power is reaching the element.
It was fine last winter. I suppose it might be related to the doors coming off for the check stays to be sorted last spring. That caused the central locking electrics in the pax door to get disconnected. I'd be surprised if it is a disconnected plug because the mirror motors are working fine.
