Door mirrors
NIL98
Both my door mirrors adjust together when the knob is set to rhs. Only adjusts single mirror when set to lhs. Fault or feature?? No mention in the book so Im guess fault :(
Neil
No not a fault .....you have, I believe, to go into settings / mirrors in the main menu on the dash display, there you will see Syncronise....untick the box and they will work individually. If you cannt find it in your book I'll have a look later to check.
[:D] You should find it on page 100, MAIN MENU>SETTINGS>COMFORT>MIRRORS then uncheck the synchronise box. That should do it ........ I'll go and do mine now!!!!!
Best regards
Should add that if you try to do this with the engine running or on the move, it won't access the menu. Can only be done with ignition 'on' & stationary. Have a nice day!! despite the rain
Ahhhhhhhh thats why I cant see it in the menu. I blame 13 yr old fingers fiddling!
Many thanks all.
Neil
ps stupid option innit? what possible use can it have??
Dunno really, really thought it was daft as well... but it may be something to do with a memory seat type package...poke the seat button and it resets the mirrors aswell???
