Hi All,
As far as I can find out there are three different types of fitment for the 944 door speakers Mine's an 86 and has the "waffle plate" Type which basically fit's flush with the door, sometime after 86 they switched to a different style which had the speaker sat into a plastic carrier which is screwed into the door with a mesh that snaps on to the plastic carrier. this sits proud of the door by about 6 mm and allows the fitting of slightly deeper speakers (the speaker backs onto the window runner, but not in the Cab models which are lucky in that they can fit much bigger speakers). The third type was the pod that fits below the arm rest and was an option I believe (It's also standard on the 968?) What I'm looking for is the second option which will allow me to fit better quality 6X4 Speakers with bigger magnets. So if anyone has some spare or knows where I can get them I'd appreciate a heads up.
Many Thanks, Tim.
Many Thanks, Tim.
