Door speakers
- Thread starter Guest
All fitted professionally, of course, by my normal ICE/air-con people, so the fit quality is also good.
I use a top end Blaupunkt head unit and this is adequate. I am tempted to use a small amp to run the front speakers and leave the head unit to drive the rears (which only provide "fill" anyway) but have not got around to it yet.
The improvement is enormous (though still not really hi-fi). My goal was to be able to hear the tunes at 100mph with the sunroof open. Goal acheived. My original speakers had torn cones etc and it is a minor miracle they made any sound at all.
Richard
The solution seems to be to go for a speaker that sits proud of the parcel shelf rather than sunk into it - my Bostons sit about an inch high
Yes, I forgot to mention that mine are the same. I thought that 'standing proud' speakers would look odd when they were fitted, but now I have just been to check mine, as I had forgotten what they looked like !
And no-one has been tempted to 'borrow' them.
R
What did you decide to do?
I'm going through the same dilema. I have bought some Infinity but they don't fit with the original water proofing rear surround in the door. I intend to return them to the shop where I bought them for advice and their suggestion is to try out some from Kickers (I thought they made shoes?).
Pioneer custom fit speakers 4 inch x 6 inch and fit straight into the rear shelf and fit flush. They are rated at 90w, model number is TS-H461. Cost about #45 new and should still be available (or equiv model). I still have these, not much use to me now and would pass on cheaply if anyone wants them and lives near the west london area.
Most 5.25 inch component speakers will fit but be sure to check for depth as the enclosures are not very deep. I used Infinity reference series speakers and it was an easy home install. The difference is night and day. If I did it again, I would put a bigger 6 inch speaker in to replace the 5.25 inch factory speakers as many will fit without difficulty and will provide better bass.
The rear speakers are also rubbish, though they really only "fill in" the sound with the fronts doing all the real work and imaging. I have a spare set of Kenwood dual mag 6x4 rears that will screw straight in under factory grills if anyone is interested.
ORIGINAL: Richard Bernau
Please do your ears a favour and upgrade rather than use the poor quality factory speakers.
Too right, though if you do upgrade, a nice system in a 911 is a small separate amp driving 6/6.5 inch fronts, little sub somewhere (only needs to be a 6" bandpass or something) and nothing in the back unless you carry back seat people a lot.
Spent a weekend fitting them. Needed to open the hole in the door card slightly. Used a shaped wooden spacer between door panel and door structure. Used screws to secure the speakers actually into the steel door structure to make sure the speakers are well-grounded mechanically. Lots of Dynamat on the door. Crossover units fit very neatly into door panel 'cubby'.
By good fortune the tweeter units are a perfect close fit in the factory tweeter housings. Whole things look absolutely 'factory'.
I've also fitted some JL Audio units in the rear shelf, which fit beautifully under the factory grilles.
Baz
