Door trim removal
- Thread starter JB 3.2
you need to pull the door interior handle and flick the rod upwards to gain acces to the allen screws. then further up the handle you will see 2 little black phillips screws holding a small cover in place,behind the cover is another allen screw..
then on the door edges you will find a series of phillips screws which need removing, the top bit of trim comes off first though and the window switch just unplugs. then the bottom just needs gently pulling off.
hope it helps
