JB 3.2
Following on from an earlier thread, I'm in the process of replacing the front speakers. Although I've managed to remove the old speaker, it would be easier to work on the aperture with the door map pocket removed. According to my Bentley manual,, its just a case of removing six screws which I've done but the pocket won't release from the door handle area. Do I have to remove the handle actuating rods, or can the pocket be removed without?
The second question concerns speaker size, the one that came out appears to be 5" diameter, but according to the archives 5.25" or even 6" should fit without modification has anyone fitted larger speakers recently? if so did they fit straight in or did you have to remove any of the door card?
As always thanks for your assistance.
Regards.....JB
Regards.....JB
