BLONDELAWMAN
I'm confused and would appreciate input from owners of 997 2s & 4s and also 997 GT3s.
Basically, it relates to the drving and handling characteristics of these cars and more than a tiny desire to switch my forthcoming order from a 4S to a GT3.
As a driver of rear wheel drive cars, i always try to get my entry speed right and drive under active acceleration around a bend: i always drive with safety systems active, but my understanding is that if i wanted to get a bit of slide/tale out, then you just give the car a touch more right foot and this leads to oversteer.
I've just read an article in GT P' and it seems to be saying that a 997 will understeer when you're pushing it a bit hard and that the way to get the car back on line is to get off the throttle mid-bend.
Without sounding too boring, i guess what i really want to know is:
1. How do you need to drive a 997 to drive it fast and safely on bends and roundabouts, etc?
2. If i need to lift off the gas in the middle of one of those long, wet, sweeping motorway run-ons for whatever reason, is a 2 or a 4 (or a GT3) going to swing round on me where my BM just carries on?
3. What really is the sketch on trailing throttles, etc. with the modern 911? If i misjudge entry speed, am i better just keeping on the gas and praying, or is PSM so good that you can hit the brakes mid-corner if necessary ending up in a hedge backwards?
4. Should i think about writing a will if i order a GT3?
Lot of questions i suppose, but i'd really appreciate all your input.
Many thanks,
Ian
Many thanks,
Ian
