Drain holes
shorthouse
My car is with OPC for its first major service and one of the many recommendations they suggest is to have the drain holes checked and cleaned, which sounds sensible, however does anyone know where are they on the 997.2 coupe?
Hi. They are either side of the battery. Two each side front and back - black rubber grommets, you need to look carefully but they are there. You can use some insulated flexible wire to carefully clean them by pushing it through, gently does it though.
You'd think, but even changing the spark plugs are not part of the service ... Everything is extra [:mad:]
