Without removing the batwing the end result will always be 'a large pool' and even if you take the time to remove it you'll probably end up with a 'not so large pool' [:'(]
There's a drain plug at the bottom of the RH side of the rad as you look at the car, so remove that and the tank cap and allow to drain, it will take a while...
Are you removing the water pump and or cylinder head? If yes to the latter remove the water pump first to empty the block; I'm not aware of a drain plug so in my case this resulted in a large pool.
I recommend a large drain pan as you'll probably end up with drips and runs from several different points as it drains.
HTH!
