Drains Located & Clean - However Neighbours Think I’m Mad
- Thread starter JonFozz
We have the best deal.
Did you run clean water down those 4 tubes and watched to see running water at each corner?
JonFozz
I did...worked a treat.911hillclimber said:Lots of people lead boring lives, we don't.
They must be in the generally same locations as the weather hits the car in the same places?
I have just had a member asking the same question regarding the location of the 981 drains and here is the Q&A
QUESTION
So I’ve come from a 987 Boxster to a 981 and as I was with the 987 I’m constantly worried about drain holes becoming blocked. With the 987 it was simple. Trombone cleaner inserted until it came out the bottom. Two at the rear and front was all I did. No problems.
So to the 981. From what I’ve seen on YouTube the drain holes when the roof is in the nearly closed position are to be found beneath a plastic pipe. On locating I tried the fore mentioned trombone cleaner but it obviously can’t be a straight run like on the 987 as I could not get it down. Pouring water proved no blockage as it ran straight out. I’ve also seen that on the level (my drive slopes down) it would come out front and rear.
So question is. How many drain holes are there and how to people keep them clear.
STEVES REPLY
The 981 has the same number of drain holes, two each end. You are doing the right thing by checking them with water. They block up more often on cars left on the street and not washed often.
When we service these cars we always check and clean them but only charge extra if they are badly blocked and we have to spend extra time on them. So I would keep it clean, carry on doing what your doing and ask your garage to check them every service then I am sure you will be fine.
I also found this on You Tube for those of you brave enough to attempt a DIY job.
www.youtube.com/watch?v=0ZUwW7jhnhI
Tracy
richardm
I read with interest previous posts on this subject, and after watching a post on YouTube (from the USA) showing the locations, decided to have a quick look. Thought I’d start with the easiest first, and opening the bonnet and removing the battery cover, I was somewhat shocked to almost see my reflection in the pool of water lying in the hollow to the left of the battery, just below where a power lead goes through the bulkhead! Using a wooden skewer to locate the drain, I managed to remove quite a bit of muck blocking it,and the water fortunately drained away. I still need to clear pipe completely and then, with some foreboding, carry on with all the others!
Adrian.
yes as mentioned on the level when pouring water down the rear drain holes you will indeed see water exiting rear and front as I believe there are just the rear holes but for some reason they drain out to the rear and to the front. Look here
https://youtu.be/2jFXBv7CG98
Adrian.
Adrian.
