Driiling airbox
- Thread starter Guest
Sorry if it sounds trival.
I did not mean to imply that anything was trivial, just an observation or two, with a view to wondering where the ideas came from, which you have already answered.
Its pretty self explanatory once you remove the airbox cover. You simply take a holesaw and drill some holes. Alternatively cut the whole side panel off. Search for Fabspeed and cup airbox to get an idea of what I am talking about. I also have a recollection that one of the 964 sites (PCGB member, John Miles/Mills???) has info on the drilling and pictures of the finished product.
RB
What is particularly good is that on the drive there/back ie on the motorway at 3000rpm the was no additional noise in the car so at a cruise it was not at all intrusive and when you nail it you get the induction roar.
ORIGINAL: Amolak911
Hi,
Thats funny, it is stated that a 964 would get a few more bhp.
http://www.porsche964.co.uk/technical/airbox_mod.htm
rgds
Amolak
Yes, but is there a dyno test or any other evidence to prove that it increases hp? And if it works on a 964, does that mean it has the same effect on a 3.2, which is a smaller capacity with less appetite for air?
Once you have the airbox cover and filter off you can see into the AFM. IMHO you will see that the airbox and snorkel are unlikely to be the cause any restriction compared with the AFM.
In any case, a couple of horsepower is much less than you can feel thru the seat of your pants. I would suggest you take the airbox cover off and duct tape the filter in then go for a drive. You will hear the difference and you can see if you feel any difference. Then you can decide if you want to start drilling or sawing. I cut mine up like the Cup airboxs but I don't expect anything but a nice noise at WOT.
I would use a new paper filter element rather than K&N - I have never seen any independent tests that show they flow better and I have seen tests that show they do not filter as well. Just in case you didn't get the hint in my reply to your other post, many folks are not big fans of K&N - based on the independent evidence, they do not do anything worthwhile and they may hurt your engine. YMMV [
ciao
Richard
Andy Tims
Whilst you might see a power increase on a dyno, that will be with fans blowing cool air into the engine bay. This will obviously not be the case when on the move when holes in the airbox result in hot air being "consumed"
I don't agree with Andy's comment regarding ingesting hot air. Where is the hot air coming from? The engine cooling fan moves so much air thru the engine bay that I simply can't see how hot air can accumulate in an area that is so close to the engine bay grill.
Richard
Maybe I could just fit a whistle next to the drivers seat and when I change gears I could blow in this whistle...?
Do you think anyone would notice...?
what a kcuf bag?[&:]
where's the little blue lights?[&:]
maybe I could tie ten pound notes to the car and listen to them flap as I drive?
Or... put a rare 200 year old scotch in the fuel tank?
Or... stick a coat hanger on the front wing?
maybe fit a towbar?
