Took the 911sc out for a spin last week and after a few miles I could hear a sound coming from what appeared the left rear wheel, in no time at all this turned into quite a loud knocking noise.
I stopped and found it stopped as well so obviously this was not coming from the engine, so started moving again and the noise re-appeared, it sounds like it's coming from something that rotates.
I have just checked the wheel bearings and all seems fine so delved into the drive shaft's, the left hand one appears to have plenty of play, a lot more than the right, the question is am I looking in the right area, is there anything else I should be checking, and if it is the drive shaft do I have to remove the hub and brakes or can I slide the shaft out with out doing this, I know it's hard to ask for a diagnosis with out seeing the car but all advice will be much appreciated.
Cheers Baz
Cheers Baz
