hello all. Recently noticed an issue. when I unlock and move the door handle to open the car the window opens slightly as it should, but When I close the door the window doesn’t return to fully closed position. In order to close it probably I have to put the ignition on to start, use the window control button on the door.
I also have a possibility related issue with the same window when trying to close it: I have to hold the button up until closed. passenger window works fine: hold for a second and it closes automatically.
anyone seen this before? It’s still under warranty so will take it in unless this there’s a quick fix? TiA
