I have a problem with my drivers door window that when I pull on the handle the window drops but then immediately returns to the fully closed position when the handle is released making closing the door difficult. I am having to drop the window once inside with the ignition on then close the door and then close the window. It is also affecting the central locking security as I have found the window drops for no reason by 3mm and the system senses this and sets off the alarm. I have checked inside the door thinking water had got in but it is bone dry. Is it a micro switch issue or something to do with the window regulator.?
Driver side window not working correctly Boxster 986 (2002 model)
- Thread starter trev
Trev,
Probably I'd favour the regulator, but your guess is as good as mine and unfortunately the only way to get a definitive answer is to run some Porsche-specific diagnostics ... and a micro-switch is going to be much cheaper than a window regulator!
This article may be useful for some initial checks, and if the other window is working maybe you could try swapping a few components?
https://www.pelicanparts.com/techarticles/Boxster_Tech/77-BODY-Window_Regulator/77-BODY-Window_Regulator.htm
Jeff
Jeff
Jonttt
Sounds like the door lock actuator.........its a DIY with a c£20 VW part (you’ll have to check the 986/VW part number) or OPC for £200 part and 3+ hours labour....
full DIY write up here....
https://www.porscheclubgb.com/forum/tm.aspx?m=1058282
