Drivers door window stuck down!
any pointers? its not the switch, as I swaped that wth the other side. Fuse is ok too. The motor seems to click when the switch is pressed? Is it simply a duff motor or could it be something else?
(wanting to cover all possibilities before I take the door card off)
Not wanting to be the harbinger of doom, but I recently had a similar problem which turned out to be a sheared off tooth of one of the cogs in the window regualtor [:(]
