drivers door wont open
its completely stuck, the handle does nothing!
have peeled back the door card to try and get to the mechanism, but cant figure out how to free it?
any ideas before the angle grinder comes out?????
No need for the angle grinder.
Had a problem with one of my doors. The rod that is attached to the inside door opener had come detached from the lock end. It may just need clicking back in position and the locking piece putting back on.
If the locking piece has broken then can be repaired using wire.
The outer handle presses down onto a lever on the locking mechanism so you may be able to find that and release the door.
If you do the job without cutting yourself you will be lucky.
Cheers,
Fred
I am guessing Fred is right. Here is a pic of an old and a new. The part number is 944.537.511.00
cheers for that I'll have another look
am I pushing downwards to release the door catch or pulling up?
