Drivers Seat Motor
- Thread starter 944Fripp
pauljmcnulty
There are six bolts to the seat, one at the front and two at the back in each runner. I've not taken one out myself, but it should be pretty straightforward. One thing to consider whilst you're fiddling around with the seats is to swap the driver's and passenger's backs over. This evens out the wear on the seat bolsters.
BUT
Before you take the seat out make sure that the electrical connection underneath them is disconnected (it plugs into a socket on the seat) and take care lifting the seat - it is PIG heavy and you will be lifting it and twisting it at the same time ...
When it is out the workings are very clear. It's worth checking connections - both to motor and seat - to ensure that they are all OK. And check the switches with an AVO meter as well. If all else fails, try applying 12v to the motor directly using a battery charger.
If you really can't make it work then you can wind the front of the seat down by hand. The seat sits on a pillar at each corner, which is threaded, and the motor spins the pillar to raise and lower the seat. The pillar has a notch cut in the top of it and it can be wound very easily with a screwdriver. It's tedious, but not difficult.
Oli, thanks for that, as with everything Porsche most things seem purely mechanical (mainly the reason I went for the car!) so I have every faith that I can at least do something with it. Presumably the electrical connector is to the switches on the base of the seat. Like you say, I'm sure it'll all be pretty obvious once I'm in there. I'll let you know how I get on.
As ever, your collective knowledge is something to behold! [
Alasdair
As it turns out it was just one of the wires to the motor had split from the connector at the motor end and in hindsight I could have fixed it without removing the seat! Still, I removed the seat regardless.
6 bolts indeed but bugger me were they tight! One had been tampered with too in a previous life and they had managed to strip the allen head. Trouble is, I only discovered that it was not coming off AFTER I had taken the seat back off (to swap with the passenger seat)! So, seeing as I had no spline extractor I had to put it all back and take it to my local garage who took it out FOC. By the way, if you're ever in need of a damn good garage in Sheffield who are just good, reliable, and super trust worthy mechanics let me know, I use them all the time. Then it was back to my workshop to finish the job including a much needed hoover up of the carpet without the seat in!
Makes such a difference. Thanks for all your help, that's one of the little jobs off the list!
