I just noticed that the drivers side parking light isn't working.
Both side lights work fine when the ignition is switched on, but if the ignition is off then only the passenger side stays on.
I have checked the parking light fuses both and swapped them around to check, but both seem fine.
What else could it be, indicator stalk, light switch?
Just found that its only the front drivers side light that isn't work, so assume its a break in the feed somewhere
