hi guys,
Wondering if anyone has had this fault and the best way to fix it. Basically, the small ball joint where the base wiper arm connects to the main rod from the motor "popped out" and is cracked. The RAC man nicely fixed it with a clip, however i would like to get it sorted properly as the clip will work its way off with time. Any ideas what this plastic part is, and if i can change it without replacing the whole rod to the motor??
Thanks, Mark.
Thanks, Mark.
