Hi,
I will be driving into Europe tomorrow and decided to adjust my headlights accordingly last night.
The manual says remove the lights and switch the position from "O" to "T". This should adjust the beam angle for right hand side driving in Europe. Then when return to the UK, switch back from "T" to "O".
... so did this on the nearside headlight and all was well. When I went to the offside headlight it may have already been in the "T" position ... the switch did not move and so went back and forth so may times that I dont actually know where it was in the 1st place. [8|]
I assume that in the UK, then both headlights should be in the same "O" position and in Europe they should both be in the "T" position? This seems to make logical sense in terms of steering the headlight beams in the same direction. but just want clarification from someone else that has done this. [
Thanks, Jason
Thanks, Jason
