Following on from the OBD seminar I had a good search on the information super highway and ended up purchasing the Durametric OBD tool. With the exchange rate being so good the cost was £151 delivered which I must say is pretty good considering how difficult it is to find an OBD tool for our cars. My car has the later rectangular OBDII port so I didn't need the converter for the 12-pin round socket (which is also available). Anyway, this weekend I plugged it in and found 3 fault codes [
], one for each of the systems - whoppee
ABS 5 : Fault code 39 Valve Relay. I think this is R68 and will have a play swapping with R65 to see whether the relay is knackered. From what I've read this is a pretty common fault and explains why the ABS/ABD warning lights illuminate occasionally. Evidently it has occurred 39 times ...
Motronic 2.1 M04: Fault code 32 Knock Sensor 2. Could explain why the car feels a bit sluggish, I think that the DME keeps the ignition retarded if the knock sensor is considered faulty although from what I've read the fault tends to be the connections rather than the sensor (it's just a piezo-electric crystal isn't it?). Anyway, have cleared the code to see whether it re-occurs in which case it's time to get under the bonnet. Does anyone know what side of the engine this refers to?
Heating: Fault code 24 Fresh air flap motor. Bit of a funny one this as the heating and aircon appear to work fine so I've just cleared it and will wait to see what happens in future.
Didn't get chance to try the actual values bit as it started raining but it looks as though it is similar information to what the Scantool software provides with the OBD interface presented at the seminar. IMHO this is a great product that does exactly what it says on the tin with the added benefit of plugging straight into a USB port (great for modern laptops with no RS232 ports). Just thought I would share this with you as another option as I remember several members at the seminar saying that they would be interested in obtaining a ready built tool rather than having to make one up.
I would provide screenshots but unfortunately the only ones I have are embedded in a Word document (and they aren't that interesting anyway). Check out www.durametric.com for further details (no affiliation etc.)
Hope this is of interest to someone
