A topic discussed last year, but it seems that these engine mounts are continuing to fail. The current issue is that there are no replacements available from Porsche or the independent parts suppliers. Folk are unable to use their cars or, in at least one case delay exchanging their car, until supply resumes at a date to be advised! If you are able to please add comments on any of the following:
- If you are affected by this
- If you have found a supply (there are a few on eBay, but not from any of the normal distributors)
- If you know of anyone who has been able to repair the mount (I believe it is a sensor failure in most cases)
- If you know of anyone who has fitted the standard passive mounts instead.
Its a grim situation.
