edh
Took the car to Weltmeister today to get the Vitesse MAF checked out - am away from home so will scan the graphs in at the weekend
Interesting results....good and bad
The good - boost is coming in earlier, by about 200 rpm, and there's consequently more power until 4500 rpm. Peak torque is up to 320lb ft at 4250 rpm, (was 315 @ 4600). AFR's also much better as the turbo spools up.
The bad - boost peaks at below 1.1 bar @ 3800 & then falls away (was 1.2 bar@ 4100). Peak power now 270 @ 4600 (was 285 @ 5250)
That might explain why I though the car was a bit flat at Silverstone in the summer & didn't really pull down Hangar Straight.
Time to play hunt the boost leak! - Chris's suggestion is the dump valve. IIRC this can be replaced by a 993 part no - is that correct?
